Missing connector to connect a WiFi module
Hello, I have a "UP gateway" and a WiFi connection "WiFi kit for UP". But when I follow the installation instructions(UP GWS01 WiFi module installation SOP)
I found out that I don't have a connector on the board, even though it should be there. So I can't connect the board and the WiFi module. I'm not sure if this is a standard HW setting or some HW error. Or is this a missing functionality of the board? if I solder my own connector, would it work?
  • FredyHsu
    FredyHsu Administrator, Moderator, AAEON Posts: 55 admin
    Hi Kubaanek,
    could you share with us the P/N and serial number of this UP Gateway. We will investigate this issue.
    UP Team
  • Kubaanek
    Kubaanek New Member Posts: 6 ✭
    Thanks for reply, here is the gateway tag:
  • Kubaanek
    @FredyHsu said:
    Hi Kubaanek,
    UP Team
    Hello, do you have any information for me?
  • FredyHsu
    Hi @Kubaanek ,
    Sorry for the late response. We have identified that this is a production issue. Please apply the RMA for us to rework. We will arrange the rework soonest we got the unit.
    I will pass this serial number information to our RMA team first.
    thanks,
    Fredy
  • Kubaanek
    Hello, thanks, before I send you the device back, can you estimate how long it will take?
