Not detecting WiFi adapter
We ordered this kit https://up-board.org/up-squared-robomaker-pro-kit/ which comes with WiFi adapter including 2 antennas. I connected it, but Ubuntu does not see it.
lspci -nn | grep -i network does not show the WiFi controller, only ethernet ones. I tried downloading the latest firmware files but no help. Looking at dmesg | grep iwl does not show anything. It seems like it is not connected at all. I am using pre-installed Ubuntu with kernel 4.15.
Not sure if antennas are connected properly, but I guess it should still recognize it. What is the best way to check if everything is connected as it should be? Any inputs on what to try next?
Regards,
Nedim
  • vrgdubey
    vrgdubey Posts: 17
    I'm facing the same problem. Please help me if you are able to solve the problem.
    DCleri Posts: 1,213 admin
    have you tried to unplug and re-plug the WiFi module?
    Can you please confirm the WiFi module type (maybe taking a picture of the module)?
    Can you also share your complete dmesg log file?
    Also what BIOS version is installed in your system, is it 5.0?
  • vrgdubey
    vrgdubey Posts: 17
    Hi @DCleri , thanks for the support.
    I had the outdated BIOS 4.2. Once I upgraded the BIOS to latest version, then the wifi module got detected.
