UP Squared not booting up, only solid blue led
Hi I am using Up Squared Celron 2GB and 32GB.
First time when i opened, it was working fine but after shutting down it doesn't respond.
It doesn't show anything, the only thing i see is the solid blue led. I've tried re-flashing but it doesn't react only. I am not able to find any useful thread on community also.
Could anyone please help me out with trouble shooting of this issue ? or suggest what should i do ?
    DCleri Posts: 1,213 admin
    Hi Suryender,
    What power supply are you using?
    Please try to unplug the board from any cable and also remove the RTC battery.
    After 5 to 10 minutes, reconnect the RTC battery, then add your USB stick with the OS installer and the other cables, then plug the power cable.
  • suryender
    suryender Posts: 6
    Hi, thank you for the response.
    I’ve grove IoT development kit, it comes with 5V@6A power supply in the box. I am using the same.
    Initially the board was working fine, next time it didn’t turn up shows only solid blue led, I’ve already tried removing the RTC battery, it didn’t work.
    I think for re-flashing also it should show something, it doesn’t show anything on screen, something wrong with boot loader or bios, I’ve no clue what’s wrong. Please suggest.
  • suryender
    suryender Posts: 6
    @DCleri said:
    Hi Suryender,
    Hi, I've tried as per the procedure suggested by but no success it still dead, no response. could you please help what to do ?
    You can try a different screen or cable just in case but before that, you can try to use this image to reflash the Operating System:
    https://downloads.up-community.org/download/up-squared-iot-grove-development-kit-ubuntu-16-04-server-image/
    follow the procedure in the description to flash the image in the "attached files" tab.
    If at the end of the procedure it does not work, please file an RMA from your account on the UP-shop. You can point this topic to describe the failure.
