Installation of WIN10_64 - Step_X fail Up Board
HI all,
i have successfully installed windows 10, but i can't install any kind of Intell drivers.
I recive an error in all step of istallation (Step-1 and step-2).
Before i download the BIOS and upgrade them!
I download the Intel driver for Up Board in Up Board site and when i run the setup it prematurely crash.
Thank you in advance
can you provide me with more details like below
1. What’s BIOS version you use
2. Which one of the windows 10 drivers you use? 32 or 64bit ?
3. What kind of information from Intel driver about "error" message
I purchased Up Board 64GB 4G!
I downloded and upgraded the BIOS from here
I downloded and tried to install the driver (Windows 10 64bit) from here
I'm at work now, tonight I will post the precise version of the Bios and the error log files.Are the setups the right ones?
Are the location download correct ? -
Attached missing information ...
Are the location download correct ?Yes, that's correct, and i have already tested it with Win10 enterprise 64bit (Ver.1709) on my UP, no problem with that driver package, no any crashes.
So, I recommend you to take further action as below
1. Re-download windows 10 drivers, to confirm the file size is 253 MB (266,068,610 bytes)
2. Check your bios update is 64bit ("go_64.nsh") for UPC1BM0X
3. Check your OS image is 64bit or 32bit
4. Try again and set OS image ID is Windows in BIOS boot
