Screen Blinking
Prior to loading latest BIOS and drivers, my screen would blink at least once a minute.
I am connected to 4K monitor. After the upgrades, its better (once every 5 mins or so)
but not fixed. I am using Redstone 1 version of Windows 10. Any other suggestions?
It looks like there's a problem with intel hd graphics to your 4k monitor, please try the following methods
Method 1: Change your screen resolution and refresh rate in intel hd graphics control panel
Method 2: Update intel hd graphics driver for your UP-Squared
Intel downloads
Method 3:Cable or Port issue, check your DP/HMDI cable connections and make sure they are work -
The drivers, cables and monitors work just fine with other Apollo Lake boards I have.
This is why I am reported it to you. Please verify that you have tested and support
4K monitors on the DP port.
Ken -
We have tested with 4K monitor, and it works well
Philips 288P, dpi 3840x2160, freq. 30Hz -
It does actually look as if Intel released some updated graphic drivers only yesterday (7th November 2017).
Could you please confirm that these latest uploads (Intel® Graphics Driver for Windows* [15.60]) are the ones we should be using with an UP Squared board running the 64 bit version of Windows 10?
Thanks! -
do you have "UP Squared fanless chassis with VESA mounting plate"?
I think the cable head is too short, I have DP 1.2 cable, newest drivers, Windows 10 and blinking too.
I will try to mill down the head borders with CNC. -
Hi Dockey,
Please update your UP2 board with the latest BIOS V3.3 which include the Intel latest released patch to the graphic and that should resolve your display problem.
