Video tearing
MICHAEL A POPE
New Member Posts: 8 ✭
I just installed ubilinux 4.0 today on my new Up Squared P4200 8GB and as I was playing some 1080p content from local storage which I recorded from the TV I noticed some slight video tearing. Is there anything I can adjust?
I tested in Kodi 17.1 and also in VLC, both have a very slight video tearing. It's completely watchable and I can live with it, I was just interested if there is a better kernel module to install or setting to tweak.
Syncing to display refresh-rate is dependent on the player, both Kodi and VLC offer a setting for this. Under Kodi the setting is called "Sync playback to display" ( Link ) In VLC I think the setting should be enabled by default.
Now, the above said, have you tried any other video? Maybe the tearing is in your recording itself? -
I have double checked kodi and I have the "Sync playback to display" on kodi 17.1 and tested through VLC as well, same problem. I've checked with another video, same problem. I tested both of these videos on my gaming rig and they worked fine so it's not the video. I also tested them on my old notebook (2012) and it worked fine there too.
Is there anything else I can try? Should I try the 'testing' repo? or maybe a different Linux Distro than UbiLinux? -
I managed to fix it.
Put the following into /etc/X11/xorg.conf and reboot
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
Option "TearFree" "true"
EndSection
NOTE: I had to create that file.
- 105 Announcements & News
- 186 Welcome Developers!
- 50 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
