No boot, just blue LED
As the title says, one of my UpBoard will not boot any more.
I use a 5v/2A that worked great and still power 3 other Upboards.
When connected to a power source just a blue LED turns on. Monitor goes into sleep-mode, so no power out the HDMI. The Ehternet LED's don't light up eigher.
It worked the last time I've used it (a month ago).
Please assist, thank you!
Try [email protected] first. It is always good to follow the standard power input.
From there, we can investigate where might go wrong. Thanks!
https://up-community.org/forum/general-discussion-up2/2259-the-board-doesn-t-work
Solution:
https://up-community.org/forum/public-up2hw/2251-up2-not-powering-on#6231
We have the same problem, no boot and only blue led.
And in this discussion the page with Solution points to nothing...
Is there someone that can help us?
Thank you
Exactly the same no-boot, just blue light issue here. Forum links all down.
Hi All, try the following ways to restart your UP
1. Push the power button, on the same side of the DC jack
2. Remove cmos battery to clear BIOS. Pull out the cable from CN1, and pull-in back after 10 seconds
Hi All, i've the same problem, but my upboards are unreachable for me, I have hundreds in the world sealed with security seals inside a box, there is no solution to make this thing no longer happen? For me is a BIG problem.
rogertsai(AAEON): it's very helpful recommendation. My board is working again. Thank you
I am having same problem just blue led, I try the power button and Pull out the cable from CN1 but nothing happen
Please follow the recommendation from Roger and also check our wiki for any further instructions: https://wiki.up-community.org/FAQs#Not_Booting_or_Powering_up
Reading from the comments I can see at least 2 different issues:
for who is using 5V3A or 5V2A in particular, you may be damaging the board in the long run as you are using it with a PSU which is lower specs than the ones advised in our shop and documentation. Please refer to this page for better clarity: https://wiki.up-community.org/FAQs#Not_Booting_or_Powering_up
if the board never powered up and you are using the correct power supply and the procedure in the FAQs does not work for you, then the board is faulty and you should apply for RMA
