no ACPI WakeUp
I don't manage to get the ACPI WakeUp working under easyVDR 3.0 (Linux easyVDR 4.4.0-93-generic #116~14.04.1-Ubuntu SMP) ...
Hi test
This function need the kernel 4.6 or above to support that -
So i try it with ubilinux
[email protected]:/# uname -r 4.9.45-ubilinux+
and a simple wakeup test
Wake Up Linux With an RTC Alarm Clock[email protected]:/# sudo sh -c "echo 0 > /sys/class/rtc/rtc0/wakealarm"
[email protected]:/# sudo sh -c "echo `date '+%s' -d '+ 3 minutes'` > /sys/class/rtc/rtc0/wakealarm"
[email protected]:/# cat /proc/driver/rtc
rtc_time : 21:09:04
rtc_date : 2017-12-21
alrm_time : 21:11:30
alrm_date : 2017-12-21
alarm_IRQ : yes
alrm_pending : no
update IRQ enabled : no
periodic IRQ enabled : no
periodic IRQ frequency : 1024
max user IRQ frequency : 64
24hr : yes
periodic_IRQ : no
update_IRQ : no
HPET_emulated : yes
BCD : yes
DST_enable : no
periodic_freq : 1024
batt_status : okay[email protected]:/# shutdown -P now
The board dont comes back up in ~3 minutes!!!
The same with "hpet=disable" as kernel Parameter, no ACPI WakeUp.
Forgives my bad english!
Yet another try under 4.9.45-ubilinux+.
NO ACPi WAKEUP!
Please, can somebody try the following in a root terminal?sudo rtcwake -m no -s 60 && sudo poweroff
The system should "poweroff" and wakeup after roughly 60 seconds, theoretical...ACPI Wake is essential for me because I want to use the UP Squared as a VDR (VideoDiskRecorder [easyVDR])!
Thanks a lot!!
Did you enable RTC wake function in your BIOS? If not, please try it and set to dynamic Time mode, and set 1 for wake up minute incr as bleow
Bios path for boot option: Advanced --> Power Management -
If I set "RTC wake system from [Dynamic Time]" to 1 the system powered up after 1 minute.
"RTC wake system from [Static Time]" works also.
But the problem is to set the wake up time by linux's ACPI Wakeup.
Under Ubilinux RTC wake BIOS funktion is disabled. -
Something is going on... after over a year ago
https://forum.up-community.org/discussion/3454/acpi-wakeup-possible -
What a beautiful housing! Did yo create this yourself or is it purchasable somewhere?
It is a "recycled" Nexcom Nise 101 case for passive cooling with custom made front & back panel from https://schaeffer-ag.de/en/
Tagged
- 301 All Categories
- 184 Welcome Developers!
- 24 Tech Updates
- 547 UP Products
- 1 UP Xtreme i12
- UP Squared Pro 7000
- 10 UP Squared V2
- 25 UP 4000
- 23 UP Xtreme i11
- 44 UP Squared Pro
- 140 UP Xtreme
- 819 UP Squared
- 221 UP Core
- 43 UP AI Edge
