I'm trying to install openelec
Bas Horneman
Posts: 22 ✭
Openelec image on usb stick. Boot up with it. Install to emmc. reboot..and there you go.
However ...the up2 does not boot up from emmc?
Any tips?
Any tips?
I don't think OpenELEC supports UP Squared. You are better off installing Ubuntu and adding Kodi, that way you get basically the same functionality, plus the option to add extra. This is what I will be doing when I receive mine, only difference is I run on LibreELEC now because OpenELEC is rarely updated anymore.
Mmmm...They do support x86 architecture. Was a no brainer installing it on my Udoo x86.
Even though there could be something amiss with the image. Udoo should still try to boot up on with emmc right? -
In the bios I can see MMC - HAG4a2 that must be it. But What mode must it be in ? Any documentation on the emmc and how to enable it?
Are you sure they support it UDOO? Isn't it just generic Intel CPU support. Otherwise pin support, HDMI CEC and hardware acceleration you probably won't get.
Yes. it is just generic Intel CPU support.
Hi Triodefreak,
The eMMC should be enabled by default.
Up Squared requires a Linux OS which supports UEFI boot and now all the major distributions enable this boot option.
Are you sure OpenElec supports UEFI Boot? I am not able to find any information on their website about this.
About the Linux Kernel support for UP Squared, if your distribution has a 4.9 kernel or newer you will get most of the features enabled, except the 40 pin header. -
Hi dcleri,
The UP2 boots up with the OpenElec installer onthe USB stick.
The eMMC is visible to the OpenElec installer.
The OpenElec installer does not report errors when installing openelec on the emmc.
On the USB it has a folder EFI. So it seems that it supports UEFI?
After booting up though...Up2 goes straight to the bios. I then thought...ofcourse it needs to know that it must boot up from the eMMC. But booting up sequence has no option for eMMC?
So I thought...perhaps the eMMC is seen like a hard disk.
So I selected hard disk as primary bootup.
But the Up2 goes straight to the bios again. -
Can you check if the eMMC has an EFI folder on it? If it hasn't then that would be a reason for it not to show up in the boot options. Which would mean that the installer installed it as a legacy BIOS boot device which (I think) isn't supported by UP2.
Sadly I'm unable to test this as I haven't received my UP2 yet. -
As Jeroenvj mentioned, I think the installer (even if it supports uefi) may have performed a legacy boot installation.
My suggestion would be to use an Ubuntu live usb, and via gparted remove all the partitions on the eMMC.
Once done, try to re-install the system with the openElec installer.
Another thing to do could be to ask in the openElec forum if the image they provide supports UEFI Boot.
There are other alternative to openElec, like LibreElec or eventually install Ubuntu 16.04 with our kernel on top and add Kodi from the official kodi team repository. -
How can one see if there is anything on the eMMc? Since the only thing you see is the BIOS? Or OpenElec installer.
Or should I have created a partion first with some kind of bootable os?
Will do the: My suggestion would be to use an Ubuntu live usb....thing you suggested. -
I tried libreelec. Since they have a special installer for putting the image on usb. Perhaps that would work for openelec as well. Might try it this weekend. Anyway...Libreelec installed on the eMMC without a problem. Thanks for all of you who helped.
Kind regards
