GPIO Breakout?
Daniel Marshall
New Member Posts: 3 ✭
Are you guys planning on selling a breakout board for the ribbon cable on the UP Core for prototyping?
Also, what type of connector will it be using? I read 100 pin, but is there a connector or is it one of those 'slide-in' types like rpi uses for cameras?
We will sell the brackout boards as we proposed on Kickstarter https://www.kickstarter.com/projects/802007522/up-core-the-smallest-quadcore-x86-single-board-com?ref=nav_search.
The 100pin connector is Panasonic AXK5S00347YG.
In UP Core, we support CSI camera, same type as Rpi, but different pin definition. -
Any update on breakout board or cable?
At least state what kind of connector should be used for "Low Speed carrier board"-s 30-pin port. -
Hi @joshi42 ,
Please, check that discussion: https://forum.up-community.org/discussion/2815/status-schedule-for-carrier-boards-and-metal-case
It looks like AAEON needs to create a new PCB schematics for the low speed carrier board
Cheers!
