Never boot win on up board
Dear All,
I need some support for my prb i am new with up-board and i try to download win 10 on it but never work i try all methods for creating USB disk but all time i
get the shell again,i try make image from Microsoft web site with its tool and also i try with downloading 64 and 32 bits iso image and use rufus 2p11 and it is the same, the prb with rufus is it is make the format NTFS and i cant change it to FAT32.
can any one give me hand on that.
Thanks.
Khaled
  • Stefan Smietanowski
    Stefan Smietanowski New Member Posts: 40
    edited March 2017
    With Shell you mean EFI Shell?
    There are two ways to solve your problem.
    1. When you power on the board, click DEL over and over until it boots you into BIOS settings, there you set BOOT ORDER to be USB first, save settings and reboot. Next startup you need to change it back so you don't always boot from it.
    2. When you get the EFI shell, look at the screen, it should say something like "fs0" and "fs1" and then "blk0", "blk1", etc.
    Type:
    fs1:
    This should give you a changed prompt that says something like
    fs1:\
    or something similar.
    Now type exactly this:
    efi\boot\bootx64.efi
    This should start the installer.
    Let us know how it goes.
    And if you want to make sure you do it in the right format, etc - use microsoft's own media creator tool.
    // Stefan
  • Khaled Ibrahem
    Khaled Ibrahem New Member Posts: 3
    Hello Stefan,
    Thanks for your update.and sorry for my delay.
    i have used another USB stick and i have it run good and boot win.
    Thanks for your support.
    Khaled.
