Ethercat and Kernel 3.xx
I need to install a version of kernel 3.XX to use master ethercat of etherlab with preemtive patch for realtime.
Is possible download an older version of Ubuntu?
Otherwise i can to install my old version of Ubuntu with kernel 3.XX, but in this way i need the hardware driver.
Who can help me?
Thanx.
  • this could be challenging..........
  • Why? Is not possible to install old version of ubuntu? Or this is not possible have driver?
  • Older kernel versions will be missing some drivers which are required for Cherry Trail support.
    v3.19 should be mostly ok, I think, depending on your needs. But versions successively older than that will have increasingly less support and some will not have enough driver support in place to boot the board.
