Mount USB at boot and reboot.
New Member Posts: 29 ✭✭
Dear all,
how can I mount a USB on boot and reboot?
I have on my USB some files that must be copied on boot and reboot.
Could you help me, please?
I tried a lot of different solution (@reboot in crontab f_or user root_, modify the_ fstab_, putting delays...) bit it does not work in any case.
Note that the USB can change, I just need something that mount any USB key connected to the UPboard when the system boots.
Thanks.
Silvano
Eng. Silvano Bertoldo, PhD
Welcome!
  • New Member Posts: 29 ✭✭
    Dear all,
    I tried o modify the following modification in_ fstab_ file. Just add the following row:
    /dev/sda1 /mnt/usb auto defaults 1 1
    It is the simplest configuration I can define in fstab file.
    But it does not work on this system, while it works on Debian standard distribution.
    Please, could you help me? Is there something I miss or I do not understand in the configuration of UPboard????
    Silvano
    I solved my problem: please note that the ubilinux OS automount the USB key in /media/[user]/[USBlabel] immediately when it is plugged, and also when you boot the system.
    After the boot, if you go to that folder you can find your USB.
    Silvano
  • Administrator, Moderator, Emutex Posts: 241 admin
    Hi @Sil
    I'm glad you found a solution. Many thanks for sharing it with the community.
    Best regards,
    -Dan
Welcome!
