Graphics not installing
whitecider
whitecider New Member Posts: 3 ✭
I have a clean windows and Bios 4.0 install. Trying to run the windows drivers from here "UP-Squared-Windows-10-64-bit-drivers" "Step 2 - Graphic" and every time I run the installer it crashes the system.
I went to device manager and tried to update the driver from there it did the same thing.
  • AleksandarH
    AleksandarH New Member Posts: 4 ✭
    Hello, I have the same problem. Did u manage to find a solution?
  • rogertsai(AAEON)
    @whitecider, @AleksandarH
    What's windows 10 version you use?
    I can run it Graphic driver without any problem on Windows 10 1073
  • AleksandarH
    @rogertsai(AAEON) Thanks for your reply,
    I'm using Windows 10 Pro, Version 1809, Build 17763.253.
  • AleksandarH
    @rogertsai(AAEON) UPDATE
    I've Installed Windows 10 Pro version, then I've tried installing Intel HD Graphics 21.20.16.4550 - It says that these version of Windows and Intel are not compatible (?? not sure why...). Then I've tried installing 21.20.16.4664 and 4815 - and UP squared restarts before the installation is complete.
    Is it possible that the hardware is faulty?
  • rogertsai(AAEON)
    edited March 2019
    @AleksandarH,
    I've updated Windows 10 from 1703 to 1809, and there's no operating problem.
    However, Microsoft will automatically update Intel HD Graphics to **25.20.100.6373 ** during windows 10 1809 installation (as picture below). So you don't need to do any update to HD Graphics driver.
