HDMI out
Hi, Is there a way to connect the HDMI screen connector to the UP CoRE board using the 100 pins dock connector? I know it has the HDMI out, but I need to to that using the 100 pins connector. Is it possible?
    The HDMI out is only available from the connector on the module, not the 100pin.
  • Earsistemas
    Earsistemas New Member Posts: 27 ✭
    Thanks for your answer.
    I know we have 3 USB outs in the UP Core (2 in CN7 and the connector in the board). If we need more USB ports, are there any posibility to have more USB ports in the 100 pins connector?
    Thanks again.
