Question about GrovePi+
Ryan6018
New Member Posts: 3 ✭
I would like to use Grove Pi+ (for Raspberry Pi ) on Up squared board for test.
But,
it seems not to work because Up squared board use the customized GrovePi+.
Can I know why? what's change or difference between them? hardware? or software?
Looking forward to your feedback.
Ryan
The original Grove Pi+ was working slightly off-spec on the I2C bus and it wasn't detected correctly by the UP Board/Squared.
The one included in our kit has the modification in place to be recognised correctly.
I am not sure if Seed added the same modification to the original GrovePi+ and since when.
