Connect SSD in Up boarad with USB3.0 busy with Realsense r200
Hi, I bougth a Robotic kit with r200 and UP board. I know is possible connect a SSD with USB adapter, I have two already of that, but the only USB3.0 is busy by the r200.
Is a surprise not pcie or SATA connectors. I read ethernet full speed via pcie port, Is there some trick to can use that (pcie rj45)to conect a SSD?
  • FPSychotic
    FPSychotic Posts: 9
    Just tell is unbelievable the lack of support of this board. 1 month and nobody could answer a SSD install question. Clear message, if you are not a genious, go to rpi or other board
