[SOLVED] Avoid GNU GRUB menu at start up
MatAff
New Member Posts: 18 ✭✭
Is there a way to avoid the GNU GRUB menu at start up? I'm using the UP board without any peripherals (keyboard, monitor), and am connecting through SSH. However currently I have to select ubilinux GNU/Linux from a menu before the board completes booting up. This means I still have to connect a keyboard, which I'm trying to avoid.
Other options in the same menu are:
- Advanced options for unilinux GNU/Linux
- System setup
The system setup takes me to the BIOS(?). I've had a look at the settings there, but haven't found the solution.
I resolved this by changing the file /etc/default/grub
sudo gedit /etc/default/grub
In this file I changed grub time out from 5 to 0
GRUB_TIMEOUT=0
After closing the file make sure to update using:
sudo update-grub
