[SOLVED] Problems with Fedora kernels >= 4.18.17
zuzzurro
zuzzurro New Member Posts: 15 ✭✭
edited November 2018 in UP Squared Linux
Hi everyone.
My Up² will not boot anymore using Fedora 29 kernels past 4.18.17. For the time being I'm forced to stay on 4.18.16. Issue seems starting mmcblk taking forever.
  • zuzzurro
    I discovered the reason for my trouble in booting. It looks like the root device minor number has changed from 0 to 1 for some reason.
    Before:
    mmc0: SDHCI controller on PCI [0000:00:1c.0] using ADMA 64-bit
    mmc1: SDHCI controller on PCI [0000:00:1e.0] using ADMA 64-bit
    mmc2: SDHCI controller on PCI [0000:00:1b.0] using ADMA 64-bit
    mmc0: new HS400 MMC card at address 0001
    mmcblk0: mmc0:0001 M52564 58.3 GiB
    Now:
    mmc0: SDHCI controller on PCI [0000:00:1b.0] using ADMA 64-bit
    mmc1: SDHCI controller on PCI [0000:00:1c.0] using ADMA 64-bit
    mmc2: SDHCI controller on PCI [0000:00:1e.0] using ADMA 64-bit
    mmc1: new HS400 MMC card at address 0001
    mmcblk1: mmc1:0001 M52564 58.3 GiB
    I don't know why, but in any case all I had to do was to modify the fstab to cope with the new numbering, hoping it won't happen again.
  • ccalde
    Hi @zuzzurro ,
    Thanks for the update about your problem.
    Kernel 4.18 is not supported yet for UP, so for the future we would recommend you to use any supported software as Wiki says:
    https://wiki.up-community.org/Software#Operating_Systems
  • zuzzurro
    Hi, I was not complaining, it was just a heads up for other people to be careful. I know that if it break I get to keep both pieces.
    All Fedora releases have been quite stable for me up to now, so no big deal. It's also good to know about the policy. Hopefully someone will be able to understand what broke precisely.
