I2S sound
specs does include I2S ports on 40 pin header, are they enabled in software? If not are there any plans for that?
I can speak for Linux kernel support - not sure about Windows or other operating systems.
The I2S controller on the SoC is supported by a driver in the Linux kernel. However, "ALSA SoC machine drivers" are also required to configure each I2S codec to work correctly with the I2S controller, and vice-versa. Machine drivers exist for specific codecs in combination with the Cherry Trail SoC (e.g. see the cht_bsw* examples here: http://lxr.free-electrons.com/source/sound/soc/intel/boards/?v=4.4), but none yet for the codecs that are typically used on I2S HATs designed for Raspberry Pi.
However, we do have plans to enable one or more I2S HATs to work with UP. We'll keep you posted on that.
-Dan
I noticed the i2s pins just I2S_CLK, DATAIN, DATAOUT, FRM.
In case of ALC5633Q codec ic, i2s need 5 signal(ADC/DAC/MCLK/LRCLK/BCLK)
How can i connect the up board with ALC Codec ic.
Thanks for your smart in advance.
I have DAC Sabre ES9023 connected to banana pro. Planning to upgrade to UP Board, hopefully support for this DACwill be available soon:)
I just want to get some basic sound from the thing without having to use another USB or rely on getting a display board that decodes it from the HDMI. I'm using the Up board in 250 Windows 10 terminals we are building and plan to build more but just need to get some basic sounds from them. I would love to just use something like the Adafruit DAC & Amp:
https://learn.adafruit.com/adafruit-max98357-i2s-class-d-mono-amp/overview
Dan was last talking about doing this about 10 months ago in another thread:
https://up-community.org/forum/general-discussion-up/99-up-board-and-audio-dac-support
Dear
Which port does UP Board use?? port 2 or 4?
Just to give you a quick update.
Good news from Intel, as they confirmed that I2S Audio is now working on UP Squared (including the DMIC) and the feature will be available soon also on UP Board.
A BIOS update will be issued for both systems and after that an official announcement with additional details and tutorials on how to use I2S with UP/UP Squared and existing Audio HATs.
Mmm, so do we have any news about I2S audio support? Does someone have a link to a (even partially working) kernel tree?
I would like to use the Picade X HAT's I2S audio, and am willing to write some code if needed, but a starting point would be nice...
Hi @DCleri
Which FW version is that?
Can I get I2S working on UP CH01T?
Are you able to tell us, when the I2S will work on the Up Board? Are we talking about weeks or about month? I would really like to use it in my current project
In the coming weeks we will publish the new BIOS for UP Squared supporting I2S new driver from Intel which they demonstrated already at the latest Embedded Linux Conference Europe this week.
About UP Board, I don't have an exact date but it might take a month.
Any further ETA updates? I'd really like to get I2S working on an UP Board.
Hi @DCleri
Regarding your previous comment:
What Operating Systems will I2S be available to after the bug fix?
Most references regard linux releases. Is it working/going to work on Windows (10)? If so, how can I get sound out of it?
Hello Mjog,
Once you have BIOS 4.0 you would need the patches available from this git repository: https://github.com/thesofproject/linux/tree/topic/sof-v4.14-rebase
At the moment they are still work in progress and the 4.15 patches for Ubuntu kernel will be available only later this year.
We expect to integrate both set of patches in January respectively for Yocto and Ubuntu.
I2S will be available only for Linux (Ubuntu and Yocto BSP).
Any update regarding to this ?
There's any news about I2S support for UPboard ?> @Lubo said:
There's any news about I2S support in UP board ? (for linux or Win10)
Any update / news ?
Still not integrated ?
Is it integrated now ?
Any news according I2S UPboard functionality ?
I would like to connect TAS5756M chip / Amp HAT from justboom.co
https://justboom.co/product/justboom-amp-hat/
Is it possible ?
