UP Squared USB 3 OTG port support for Ethernet over USB?
javaspaces
javaspaces New Member Posts: 1 ✭
Hi everyone,
Can someone please help me to know what is required for the UP Squared to utilize its USB 3 OTG port to support IP over USB?
This is the use case that I want to support. I want to use Windows 10 with the UP Squared (or the UP Board if possible) with its USB 3 OTG port to be plugged into a desktop PC (also running Windows 10), and the desktop is able to communicate with the UP device via a private IP address.
Thanks everyone
  • rogertsai(AAEON)
    @javaspaces
    See the below information from intel, you can see Apollo lake (UP^2) don’t support OTG function with WIN 10. UP board don't support OTG with Win10, either. But it can run OTG functon on Linux. About Ethernet over USB, could you explain it in more detail about how to connect and control between UP^2 (or UP) and PC?
