up squared shut down easily during running Realsense D435
I am using intel Realsense camera D435 in ROS in an up squared, but every time I do downsampling with point cloud or even just run the tutorial from realsense2-camera, the up squared used up CPU computation easily and shut down suddenly. why, could you please help me, thank you.
@absorbraver said:
I am using intel Realsense camera D435 in ROS in an up squared, but every time I do downsampling with point cloud or even just run the tutorial from realsense2-camera, the up squared used up CPU computation easily and shut down suddenly. why, could you please help me, thank you.What exact model and rating is the power supply that you are using?
What you describe usually indicates a poor PSU. I know by experience that just because a PSU says it is 5 Amps, that it really isn't and fails with just 1 amp or even less. There are so many fakes out there.
Personally, I only use the PSUs from UP's shop now as I can't find a better source
My PSU is 5V/3A, maybe it's the problem, thank you for your advice, I will buy a new power supply unit with 4A.
UP Squared recommends a 6A power supply. This is the only one I use now:
https://up-shop.org/up-peripherals/126-up-squared-power-supply-5v6a.html
