BIOS Setting
kumar
kumar Posts: 6
edited October 2017 in UP board BIOS
HI,
I am trying to integrate Upboard with CoDeSys(Soft PLC). Codesys needs some setting changes in bios like folloing...
1. Deactivate hyperthreading in the BIOS
2. Disable Speedstep
3. Disable c-states.
How to enter into bios setting and carryout the changes required.
Regards,
Kumar/.e
  • patvey
    patvey Posts: 1
    Hi Kumar, How did you go running CoDeSys on the UP Board? I am looking for an industrial version of the Raspberry Pi, knowing CoDeSys runs on that. I would like to end up using the UP board instead. How did you go with it?
