Connecting 4 Intel Cameras on Up Squared
            Hello everybody,
I'm currently working on a project where I have to connect 4 cameras from Intel (D435) on an Up Squared. I saw that there is 4 USB 3.0 but only 3 of them are USB A and the fourth one is a USB micro B. We already test with a USB micro B to USB C cable to connect a camera on this port but it didn't work... So, is it possible to connect a camera on this port ? If so, how ?
I work on an Up Squared with Ubuntu 18.04.1 LTS.
Thanks.
Kevin
            Hi @bertrand2310 , I think the easy way is to use a microUSB to USB cable or an USB hub for all cameras, makes senses? Cheers!
            Hi @ccalde We try the hub but and this can be a solution but we prefer connect one camera per port because if we connect at least 2 cameras on one port, some latence appears. And for the microUSB B to USB cable was also a test we realized and it didn't work... Thanks
            Hi @bertrand2310, You need to install one specific Linux system for UP board... https://wiki.up-community.org/Ubuntu Ubuntu 18 is still not supported for UP platforms. Cheers!
