Boot an upcore over network PXE
tgayet
in UP Core BIOS
Having several up-core, I need to boot in PXE via my dongle usb / ethernet.
The PXE has been activated in the bios and normally my bios is up to date with the latest version.
I have tried several but none is recognized and no network is not functional.
Which USB / Ethernet dongles are functional? Can you provide a listing?
Can the PXE boot be done on any usb port?
Is there a version of bios before it works?
Thank you in advance for your return.
Thierry
i have used this dongle that usually works fine with any bios : https://www.amazon.fr/Plugable-Adaptateur-Gigabit-Ethernet-AX88179/dp/B00AQM8586
by the i wanna add that i have tried to boot using ipxe (gpxe was too old) on an usb key but it do not allow to boot over pxe.
