power for usbhub over otg port
Andrew Hays
Andrew Hays New Member Posts: 45 ✭✭
edited July 2018 in UP Board Android
this is likely a very old and re-asked question...
I noticed while trying to get a USB3 powered hub working on my OTG port that it's powering my up-board. As in supplying enough power that it still runs when i turn the up-board's power brick off... Is this OK? it wont cause any damages? no clashes?
2 x UP board, 4GB RAM + 64 GB eMMC w/ vesa case
1x UP Squared Pentium Quad Core, 8GB RAM, 128GB eMMC w/ vesa case
1x UP Core Plus E3950, 8GB RAM, 64GB EMMC+ Net Plus i210-IT
1x Dell Power Edge R510
2x Dell Power Edge R610
  • Andrew Hays
    Welp... Bye Bye kick starter edition... It really didn't like my new USB hub. sad face
    Try to unplug everything and also disconnect the CMOS battery for few minutes, then try again but do not power the UP Board via USB OTG.
  • Andrew Hays
    sorry i took so long to answer. the up board does power up again but i haven't had the chance to plug it into a HDMI cable to ensure its working 100%.
    my man cave is a mess
  • Andrew Hays
    can confirm 100% that your recommendation has worked... CentOS is installing on to it now
