Can up board support waveshare High precision AD/DA module?
absorbraver
New Member Posts: 3 ✭
The waveshare High precision AD/DA module is designed for raspberry, so can it be used in up board? and why?
Sure, it's physically compatible and uses just SPI + some GPIOs. You will just have to modify the code slightly to use something like mraa for SPI and GPIO instead of the bcm2835 functions used on the raspberry.
