Up squared serial port is not working
amolv105
New Member Posts: 4 ✭
I have installed ubuntu 16.04 server on UP squared grove, i have connected USB cable to micro usb port on Up square and Laptop, i am able to boot the Up square but serial port is not working when i check with device manger->ports in setting. i also checked with arduino create , there also same issue.
i have solved the issue, now serial port is working fine.
Hi amolv105, I have met the same issue with you. So could you tell me how to fix this issue? Thanks so much in advance.
