Need Help : How to boot Linux OS from USB in Up squared board
I need to boot Linux OS from USB in Upsquared Board.
Can anyone please tell me the procedure ...
Thanks & Regards,
Mohit Gahlyan
            你可以安装gentoo
 当安装引导器的时候使用以下命令:
 grub-install --target=x86_64-efi --efi-directory=/boot --removable
 /boot是一个ESP分区
            you can install gentoo linux
 or
 compile kernel & install grub to ESP partition, the ESP must be fat32 formatI don't speak English well, I'm sorry
            thanks tonyvicky .
 I will try gentoo linux and share the results.My criteria is :
 Linux OS should not install on eMMC.
 Linux OS should only boot from USB.I have one query :
 Have you tried booting from gentoo Linux without installing it on eMMC ?Thanks & Regards,
 Mohit Gahlyan
            yes, I tried booting gentoo from usb hardDisk on Intel-Joule,
 I have a up-board,I will try it later.
 Tell you the result tomorrow
            Hi tonyvicky, I tried gentoo OS , but Up squared board did not boot. Steps :
 1. download gentoo OS from https://mirrors.kernel.org/gentoo//releases/x86/20160704/ URL.
 2. Change the boot order in Up squared BIOS for boot from USB.
 3. Plug in the USB.
 4. Restart the Up squared board.Please let me know if I am missing anything. Thanks & Regards,
 Mohit Gahlyan
            look at this video  https://youtu.be/gpXUIJU6seg https://youtu.be/gpXUIJU6segActually you only need one ESP and one root partition, then install grub to ESP
            Hi @mohitgahlyan , Did you try to follow the Ubuntu instructions for UP2 board?
 https://wiki.up-community.org/UbuntuCheers!
