How to disable USB Panel and USB 3 OTG ports in BIOS?
tallen
Posts: 4 ✭
I'd like to disable the USB Panel (CN16) and USB 3 OTG (CN13) ports on the Up Squared board, Is that possible through the BIOS? If so, where would those settings be, exactly? I updated the BIOS to v. 3.3, but no new settings for the OTG port showed up at all.
Hi @tallen ,
Sorry but I think it is not possible...
In BIOS advanced settings you could set USB configuration about HCI and mass storage driver only.From command line you should be able to do ti using echo disabled or echo suspend to the usb patch...
Cheers!
