Linux reboots randomly
Since a few days my Up2 reboots randomly.
uname -a
Linux up2 4.13.0-37-generic #42~16.04.1-Ubuntu SMP Wed Mar 7 16:03:28 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I also installed tuptime and this shows for tuptime:
System startups: 47 since 11:30:25 2018-03-09
System shutdowns: 0 ok - 46 bad
and for tuptime -l
Startup: 44 at 20:29:36 2018-03-14
Uptime: 2 hours, 0 minutes and 25 seconds
Shutdown: BAD at 22:30:01 2018-03-14
Downtime: 12 minutes and 20 secondsStartup: 45 at 22:42:21 2018-03-14
Uptime: 4 hours, 27 minutes and 40 seconds
Shutdown: BAD at 03:10:01 2018-03-15
Downtime: 13 minutes and 4 secondsStartup: 46 at 03:23:05 2018-03-15
Uptime: 4 hours, 1 minute and 57 seconds
Shutdown: BAD at 07:25:02 2018-03-15
Downtime: 11 minutes and 27 seconds
I already checked syslog, kern.log and auth.log but found nothing suspicious.
Anybody any idea what I can check/do to find out why my box reboots randomly?
Thomas
Same problem here, on a on Pentium Quad Core, 8GB RAM. Twice or three times after rebooting, it shuts down for a long while. I updated to new UEFI BIOS 3.3 and temperatures seem to be up to 40ºC. I'm wondering if it's a cooling problem, but I'm not sure. This problem persists no matter if I boot from Linux Mint 18.3 Cinnamon, Batocera.linux 5.14 or Ubuntu 17.10.
Any idea?
Thanks you in advance,
4ng3l
Upgrading to active cooling seems to solve the problems reported in my system. I hope this info can help other people with the same problem.
After few weeks I have notice that active cooling is not enough (at least the part EP-FNDCACTCLUPS I've got provided by UP Shop). I also had to retrieve the top of the case in order to prevent reboots. If I leave it installed, system reboots after a while running Batocera Linux, or under a high load task on Linux Mint. I wish I have bought a better cooler
