Linux reboots randomly
Code2k
Code2k New Member Posts: 1 ✭
Since a few days my Up2 reboots randomly.
uname -a
Linux up2 4.13.0-37-generic #42~16.04.1-Ubuntu SMP Wed Mar 7 16:03:28 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I also installed tuptime and this shows for tuptime:
System startups: 47 since 11:30:25 2018-03-09
System shutdowns: 0 ok - 46 bad
and for tuptime -l
Startup: 44 at 20:29:36 2018-03-14
Uptime: 2 hours, 0 minutes and 25 seconds
Shutdown: BAD at 22:30:01 2018-03-14
Downtime: 12 minutes and 20 seconds
Startup: 45 at 22:42:21 2018-03-14
Uptime: 4 hours, 27 minutes and 40 seconds
Shutdown: BAD at 03:10:01 2018-03-15
Downtime: 13 minutes and 4 seconds
Startup: 46 at 03:23:05 2018-03-15
Uptime: 4 hours, 1 minute and 57 seconds
Shutdown: BAD at 07:25:02 2018-03-15
Downtime: 11 minutes and 27 seconds
I already checked syslog, kern.log and auth.log but found nothing suspicious.
Anybody any idea what I can check/do to find out why my box reboots randomly?
Thomas
  • 4ng3l
    4ng3l New Member Posts: 6 ✭
    Same problem here, on a on Pentium Quad Core, 8GB RAM. Twice or three times after rebooting, it shuts down for a long while. I updated to new UEFI BIOS 3.3 and temperatures seem to be up to 40ºC. I'm wondering if it's a cooling problem, but I'm not sure. This problem persists no matter if I boot from Linux Mint 18.3 Cinnamon, Batocera.linux 5.14 or Ubuntu 17.10.
    Any idea?
    Thanks you in advance,
    4ng3l
  • 4ng3l
    Upgrading to active cooling seems to solve the problems reported in my system. I hope this info can help other people with the same problem.
  • 4ng3l
    After few weeks I have notice that active cooling is not enough (at least the part EP-FNDCACTCLUPS I've got provided by UP Shop). I also had to retrieve the top of the case in order to prevent reboots. If I leave it installed, system reboots after a while running Batocera Linux, or under a high load task on Linux Mint. I wish I have bought a better cooler :(
