How to separate the heat sink?
kaizen95
New Member Posts: 2 ✭
I bought Up-board, Up-core, and case.
The board is equipped with a heat sink. So I could not mount the board in the case.
(The case has a block sink to replace the heat sink.)
(I can remove the block sink, but the case is useless.)
So I want to remove the heat sink, but I do not know how to remove it.
Forced use of my hands?
used Google translate. (Some words may be misleading.)
ahm... I found this, can I do this?
https://wiki.up-community.org/How_to_remove_heatsink -
Yes....this is how it should be removed.
