OS installation on SATA disks ?
New Member, UP reseller Posts: 8
Hello to All,
I have got following questions concerning Windows installation on Up Square (UPS-C2-A10-0432):
Would it be possible to make an installation from DVD reader with Windows 10 Pro / or Windows 7 Pro installation disk to SSD or classic HD disk attached to UP Square via mSata ? And then to force the UP Square to boot up from the hard disk with OS installed (in previous step) attached to mSATA ?
Many thanks,
Pawel.
  • New Member Posts: 350 ✭✭✭
    Hi invis,
    You will find that DVD reader in BIOS boot menu if you plug in your DVD reader to UP^2. Regarding to SSD/HDD, you can install Windwos 10 to SDD or HDD from SATA & mSATA port, and change boot order from BIOS.
    Note, UP Squared is not supported for windows 7
    BIOS Boot menu - BUFFALO Optical Drive (DVD Reader)
    Bios settings for mSATA
Welcome!
