S.USV UPs firmware version 2.40 reboots after power failure
asilva
asilva New Member Posts: 13 ✭
edited March 2018 in UP Squared Linux
hi,
With last firmware version, 2.40, it reboots after i unplug the energy. Is this a bug (it didn't occur with previous firmware!) or some desired configuration (how can i disabled it)?
anyone experience the same behaviour?
NOTE: the susv daemon is not running.
root@ubilinux4:~# /opt/susvd/susv -status
  • S.USV solutions *
  • www.s-usv.com *
  • Model: UPs *
  • Firmware Version: 2.40 *
  • Software Version: 2.32 *
  • Mail notification: Disabled *
  • Timed Boot: Disabled *
  • Boot time: 00:00:00 *
  • Timed Shutdown: Disabled *
  • Shutdown time: 00:00:00 *
  • Mon Mar 5 23:20:59 2018 *
  • Powering Source: Primary *
  • Charging circuit: ONLINE *
  • Charging current: 300 mA *
  • Voltage in: 5.11 V *
  • Battery capacity: 100.00% *
  • Battery voltage: 4.20V *
  • Power Battery: 000.00 mA *
  • Power Extern: 000.00 mA *
  • Shutdown timer: -1 *
  • Autostart: disabled *
  • Sleep timer: 1 *
  • asilva
    just test new version 2.51 and i can confirm that is fix.
    • Changes V2.51 - 03/21/2018
      • Bugfixing power off system after shutdown process
