power draw
what is the minimum power requiremenets for those four square boards?
May I use a 5v 3A charger as input?
  • Troy Lin
    Troy Lin Guest Posts: 33 ✭✭
    5V/3A may not be sufficient as it only provides 15W of total power. Suggest to use 5V/4A as minimum, best to use 5V/6A to make sure everything works fine.
