Micro SD on Windows
Hi there
I try to use 8 pin micro SD slot to connect an 8GByte uSD card to my UP Board with windows 10 PRO but when enter the card in slot nothing will be happened, i check small hardware, every thing is OK but i can't see micro SD drive.
SDIO driver installed successfully.
i restart system more and more but not helpful.
thanks.
any one connect uSD in windows 10 ?
What's SD card reader you use?
i dont use card reader, i 'll connect uSD directly to 40 pin expansion port with SD IO pins.
Unfortunately, UP can't support direct SDIO from 40 pin. So you need a external SD card reader for your application. please refer to the HAT40 pinout below from UP wiki
https://wiki.up-community.org/Pinout -
but in the "UP-CHT01" PDF file from AAEON page 23 says SD IO pin is available!
