Multimedia Audio Controller, etc.
Edgett
Edgett New Member Posts: 7 ✭
I installed Windows 10, patched it, and installed the chipset, graphics, ppm-apl, and Serial IO drivers.
I still have the following "Other devices" with missing drivers.
[ul]
[li]Multimedia Audio Controller[/li]
[li]Universal Serial Bus (USB) Controller[/li]
[li]Unknown device[/li]
[/ul]
Where do I get these drivers?
  • Normen
    Normen New Member Posts: 4 ✭
    For the Multimedia Audio Controller you have to change a setting in the BIOS:
    [ul]
    [li]Navigate to the “Chipset” Tab[/li]
    [li]Choose “South Bridge”[/li]
    [li]Choose “HD-Audio Configuration”[/li]
    [li]Set HD-Audio DSP to “[Disable]”[/li]
    [/ul]
    Look here: https://up-community.org/wiki/Audio
  • Edgett
    edited September 2017
    Well, tried that. That the Multimedia Audio Controller issue, but now I suddenly have more items showing:
    [ul]
    [li]PCI Device[/li]
    [li]USB Serial Bus (USB) Controller[/li]
    [li]Unknown Device[/li]
    [/ul]
  • Edgett
    Anyone?
  • FRod1981
    FRod1981 New Member Posts: 2 ✭
    same here the navigation for drivers is horrendous. I cant get my M-Sata card working because I cant even tell what driver I'm supposed to use.
