Power button not starting the UP board
stan
stan New Member Posts: 3 ✭
I‘m having the following problem with the regular up board (4gb 64gb) using the 5v6a power supply (intended for up2) and win10pro:
The powerswitch does not turn on the board. The board does boot up immediately when the power supply is connected and i can shut it down with a single press on the power button, but the same button does not boot it up again. Only way i could find is to disconnect and reconnect the power supply.
Is that normal behavior? How can i make the power button turn on the up?
  • stan
    No answer? Could someone at least say if that is normal behavior or if somethings wrong with the board or maybe BIOS settings?
  • stan
    In case someone is having the same problem:
    I did a BIOS update to UPC1DM07, now long pressing the on switch does actually work!
