Changing Boot Order
David Hunt
New Member Posts: 7 ✭
I initially posted this as a question, but after posting found a simple answer, that F7 will allow entry into the bios menu. Just like many, many PCs I've used in the past (along with <del> and F2. I guess I was eager to post something!
That is exactly the idea behind the UP Board! The experience should be as similar (and simple) as possible like a traditional PC.
Thanks for your feedback and welcome to the UP Community!
Once in the BIOS settings, you can turn off "quiet boot", and that will produce on-screen reminders about how to interrupt the default boot sequence.
(IMHO, boards should be shipped that way ... then, the user * knows* what to do ... if they choose to make it quiet, that's fine with me.)
