Changing Boot Order
David Hunt
David Hunt New Member Posts: 7 ✭
edited June 2016 in UP board BIOS
I initially posted this as a question, but after posting found a simple answer, that F7 will allow entry into the bios menu. Just like many, many PCs I've used in the past (along with <del> and F2. I guess I was eager to post something! :)
    That is exactly the idea behind the UP Board! The experience should be as similar (and simple) as possible like a traditional PC.
    Thanks for your feedback and welcome to the UP Community! ;)
  • Stan Sieler
    Stan Sieler New Member Posts: 5 ✭
    Once in the BIOS settings, you can turn off "quiet boot", and that will produce on-screen reminders about how to interrupt the default boot sequence.
    (IMHO, boards should be shipped that way ... then, the user * knows* what to do ... if they choose to make it quiet, that's fine with me.)
