SSD not detected
I'm using the upboard squared and I have an issue with the official 128GB SSD available on the shop. It is not detected by the system.
I'm running ubilinux.
here is the output of fdisk -l
Disk /dev/mmcblk0: 29.1 GiB, 31268536320 bytes, 61071360 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 893C6070-4F32-4733-9001-E11DA25BE3CB
Device Start End Sectors Size Type
/dev/mmcblk0p1 2048 1050623 1048576 512M EFI System
/dev/mmcblk0p2 1050624 61071326 60020703 28.6G Linux filesyste
Disk /dev/mmcblk0boot1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0boot0: 4 MiB, 4194304 bytes, 8192 sectors
and lspci
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Host Bridge (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Device 5a85 (rev 0b)
00:0e.0 Multimedia audio controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Audio Cluster (rev 0b)
00:0f.0 Communication controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Trusted Execution Engine (rev 0b)
00:12.0 SATA controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SATA AHCI Controller (rev 0b)
00:13.0 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #1 (rev fb)
00:13.1 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #2 (rev fb)
00:13.2 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #3 (rev fb)
00:13.3 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #4 (rev fb)
00:14.0 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port B #1 (rev fb)
00:14.1 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port B #2 (rev fb)
00:15.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series USB xHCI (rev 0b)
00:15.1 USB controller: Intel Corporation Device 5aaa (rev 0b)
00:16.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #1 (rev 0b)
00:16.1 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #2 (rev 0b)
00:16.2 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #3 (rev 0b)
00:16.3 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #4 (rev 0b)
00:17.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #5 (rev 0b)
00:17.1 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #6 (rev 0b)
00:17.2 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #7 (rev 0b)
00:17.3 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series I2C Controller #8 (rev 0b)
00:18.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series HSUART Controller #1 (rev 0b)
00:18.1 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series HSUART Controller #2 (rev 0b)
00:19.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SPI Controller #1 (rev 0b)
00:19.2 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SPI Controller #3 (rev 0b)
00:1a.0 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PWM Pin Controller (rev 0b)
00:1c.0 SD Host controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series eMMC Controller (rev 0b)
00:1e.0 SD Host controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SDIO Controller (rev 0b)
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Low Pin Count Interface (rev 0b)
00:1f.1 SMBus: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SMBus Controller (rev 0b)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
Is this a common problem ?
double check the part number of the ssd on your board.it should be on the top of your board near the 40 pin hat.
Nicola Lunghi -
Problem solved after upgrading bios to version 3.3
Thanks for reporting back!
