wifi antenna
Tucker
Tucker New Member Posts: 3 ✭
edited January 2018 in Peripherals
Just installed this m.2 wifi antenna on my up squared board: https://up-shop.org/up-peripherals/109-m2-2230-wifi-kit.html
Using this case: https://up-shop.org/up-peripherals/123-up-squared-case-abs-plastic.html
The case wont close with the wifi antenna because there is no where for the antanae to poke out of the case. Am I supposed to wind it up inside the case or what?
