Up Squared Antenna Kit?
Michael Miller
New Member Posts: 95 ✭
in Peripherals
I have an Up Squared with the metal chassis and I already have a WiFi/BT card. I was wondering if there were any plans to have a Up Squared Antenna kit similar to the one fir the core? Just the antennas/bulkhead pigtails without the card?
All kits are packed from our supplier. I am afraid we can not sell antenna and IPX cable alone.
For my UP2 I purchased the Card from Amazon and tried a couple of different Ant setups. Currently I am using:
https://www.amazon.com/PORJET-Pair-Ipex-Mhf4-Antennas/dp/B01E29HV38/ref=sr_1_2?s=electronics&ie=UTF8&qid=1511793535&sr=1-2
Earlier I used: https://www.amazon.com/PORJET-RP-SMA-Antenna-Soldering-Wireless/dp/B01E29566W/ref=pd_bxgy_147_2?_encoding=UTF8&psc=1&refRID=P50HYAJYCCDD82JAHGS3
But they were pretty bulky and I have the plastic case.
Not sure if any of these would work for you and/or if you can purchase from Amazon, but if so you might take a look at some of their options. -
I have the metal case and I currently have the same antennas as you are currently using but mounted to the outside. It works, but they are pretty ugly so I was hoping to get something that looked a little nicer.
I had the same problem. I bought antennas and cables from eBay:
https://www.ebay.com/itm/2x-6dBi-2-4GHz-5GHz-Dual-Band-WiFi-RP-SMA-Antenna-2x-35cm-U-fl-IPEX-Cable-N8S5/253164175120?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2648
