Can it be powered via the 40pin connectors 5V pin?
Henning E. Larsen
New Member Posts: 3 ✭
Is it possible to power the UP Board via the 40pin connectors 5V pin?
Yes its possible
but requires a good stabilized 5V power supply
Nicola Lunghi -
Thanks Nicola,nicola-lunghi wrote:Yes its possible but requires a good stabilized 5V power supply
Nicola Lunghi
I was planning to use TDK-Lambda CC6-2405SR-E right on the connector. It supplies only 6W though (5V, ~1A) so probably it will not be sufficient after all.
Manual for up-board seems to indicate that it requres (5V, 4A) 20W power supply.
Any data for actual power consumption ?
br henning -
Hi heel
we have made some measurements with an embedded project that was reading data from two sensor via I2C and transmitting it every 10 seconds and the power consumption was like this:
(up boardwith 1 Gb without display with lan disabled and a GSM module on USB):Mean Current (5V power supply) 350mA Mean power (5V power supply) 4.12w Peak Current (5V power supply) 457mA peak power (5V power supply) 5.5W
Of course if you plan to use a Desktop environment/Video or CPU hungry task, or to connect USB devices you need the suggested power supply.
Nicola Lunghi -
my application is also embedded control.
thanks nicola for the comprehensive answer - perfectly the answer I was looking for. br henning -
Ni Nicola,
How do you get:
" Mean Current (5V power supply) 350mA
Mean power (5V power supply) 4.12w " ?If your mean current draw is 350mA @ 5V shouldn't the mean power consumption be 0.35A x 5V = 1.75W?
