[SOLVED] Is Ubilinux enabled for SSH mode? And how about it?
Fabio
Fabio New Member Posts: 22
edited May 2019 in UP Squared Linux
In ubilinux UP2 board can you 'activate' SSH mode as well as Raspberry?
If so how? Is there a guide or tutorial?
Thanks for any answers
  • WereCatf
    There should be an SSH-server already installed.
  • Fabio
    I thought I would use Cayenne app for a simple programming. Setting the up2board as if it was a Raspberry. But the SSH server knows I'm not enabled. If I try to log in and pass it.
    Has anyone tried it?
  • WereCatf
    I'm not familiar with that Cayenne, but you can install an SSH-server, if one isn't installed yet, with
    sudo apt -y install openssh-server
    in a terminal, or use the GUI package-manager to install openssh-server.
  • Sil
    Sil New Member Posts: 29 ✭✭
    I installed _ublinux _on my UPboard and the SSH server is already on it.
    Eng. Silvano Bertoldo, PhD
  • ccalde
    SSH mode should be installed for Ubilinux during installation.
