[SOLVED] Is Ubilinux enabled for SSH mode? And how about it?
Fabio
New Member Posts: 22 ✭
In ubilinux UP2 board can you 'activate' SSH mode as well as Raspberry?
If so how? Is there a guide or tutorial?
Thanks for any answers
There should be an SSH-server already installed.
I thought I would use Cayenne app for a simple programming. Setting the up2board as if it was a Raspberry. But the SSH server knows I'm not enabled. If I try to log in and pass it.
Has anyone tried it? -
I'm not familiar with that Cayenne, but you can install an SSH-server, if one isn't installed yet, with
sudo apt -y install openssh-server
in a terminal, or use the GUI package-manager to install openssh-server. -
I installed _ublinux _on my UPboard and the SSH server is already on it.
Eng. Silvano Bertoldo, PhD
SSH mode should be installed for Ubilinux during installation.
