MIPI CSI 4 lane
Federico ManzanFederico Manzan New Member Posts: 3
We want develop a new MIPI camera board.
We want use:
- aptina 14Mpix - HiSPi (http://www.onsemi.com/pub/Collateral/MT9F002-D.PDF)
- FPGA Lattice to bridge HiSPi to MIPI
- MIPI connector to UpCore
We want utilize Aptina, and not a little nice Mipi camera, because we can found this component for more more years.
Questions:
- where I can found connector, drawing and name ... of UpCore
- the Mipi connector 4 line of UpCore is the same of UpSquared?
- We work under Linux, I think we need to write new Mipi driver, you know if the documentation if available?
  • AlingAling Administrator, AAEON, UP reseller Posts: 524 admin
    UP Core documentation, such as drawing and connector type, will be released upon mass production. So that we can make sure it is the most updated version.
    UP Core uses the same mipi-CSI connector as UP Squared, you can refer the connector type https://up-community.org/downloads/category/56-up-squared-connector-descriptionshere.
    For the driver development, you will need to seek for Intel's support. They have more detailed documentation on driver development. We are not allowed to release due to NDA.
    Will be cool to see different CSI camera option for UP. :-)
  • Federico ManzanFederico Manzan New Member Posts: 3
    Thank for reply.
    Can you send me, also on private mode, the contact with Intel, to start ask, for sign NDA and to have the docs.
    Intel's window is assigned by country. I suggest you contact local Intel development center, and they should have a right contact for you.
