Root partition only mounts with 4.6G of space (instead of ~50Gb)
Greg BOWMAN
New Member Posts: 2 ✭
[moved from General Discussion UP Board]
Hi - I just received my 4Gb/60Gb up-board. I updated the bios and installed Ubilinux 4 for the first time - all very straight forward. However, I noticed I ran out of space as soon as I started loading data into the root partition. I see that is because I only have available 4.6Gb in the root partition (instead of > 50Gb).
Running lsblk I can see the full drive space for mmcblk0p2:
But then I can see /dev/mmcblk0p2 is not mounted correctly and I am out of space:
I don't know if my fstab is of use:
I just can't seem to figure out the issue - anyone got any ideas ?
root@ubilinux:/var/log# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT mmcblk0 179:0 0 58.3G 0 disk ├─mmcblk0p1 179:1 0 512M 0 part /boot/efi └─mmcblk0p2 179:2 0 57.8G 0 part / mmcblk0boot0 179:256 0 4M 1 disk mmcblk0boot1 179:512 0 4M 1 disk mmcblk0rpmb 179:768 0 4M 0 disk
root@ubilinux:/var/log# df -h Filesystem Size Used Avail Use% Mounted on udev 1.7G 0 1.7G 0% /dev tmpfs 336M 14M 323M 5% /run /dev/mmcblk0p2 4.6G 4.1G 187M 96% / tmpfs 1.7G 45M 1.6G 3% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 1.7G 0 1.7G 0% /sys/fs/cgroup /dev/mmcblk0p1 511M 256K 511M 1% /boot/efi tmpfs 336M 8.0K 336M 1% /run/user/1000 root@ubilinux:/var/log#
root@ubilinux:/var/log# cat /etc/fstab # /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # <file system> <mount point> <type> <options> <dump> <pass> # / was on /dev/mmcblk0p2 during installation LABEL=root / ext4 errors=remount-ro 0 1 # /boot/efi was on /dev/mmcblk0p1 during installation UUID=A9CE-4035 /boot/efi vfat umask=0077 0 1 root@ubilinux:/var/log#
FIXED
I re-installed ubilinux from scratch and now the root partition is 57GB instead of 5GB. I have no idea why the first installation did not finish setting up the partition. I noticed that Ubilinux is first installed into a 5GB partition and then, I presume, towards the end the remaining space is made available to the partition. It sounds like my install did not finish the entire job first time around. When installing I waited until the very end -- the blue light will go off. Et voila - all is good.
