Bit berfect playback on Up Board Intel Atom x5 Z8350
Katran
New Member Posts: 9 ✭
Hi Guys!
I want to make Bit-Perfect Audiophile Music Player and have some questions..
Could you please clarify what audio codecs are supported by this board?
Is be used integer or fractional clock dividers?
How good is quality of upsampling and downsampling of this CPU?
Would be able to support 44.1 KHz sampling frequency without any resampling?
Dear Katran
what board/hat do you think of using?
Nicola Lunghi -
I want to use UP board 2GB + 32 GB eMMC memory, but what board is the best for this task?
nicola-lunghi wrote:Dear Katran
Nicola Lunghi
No specialist to clear up this question? -
Dear Katran
The board has audio through the HDMI interface.
You can also attach an USB soundcard to it.
Best Regards
Nicola Lunghi -
I know it! How about using interface 40 pin to connect I2s DAC?nicola-lunghi wrote:Dear Katran
Best Regards
Nicola Lunghi
Could you please clarify what audio codecs are supported by this board? I attend to use AK4494s I2s DAC. Is it possible?
http://www.ebay.com/itm/DUAL-AK4495S-DAC-decode-board-dual-soft-control-support-DSD-IIS-finished-board-/272810159358?hash=item3f84c0acfe:g:NagAAOSw8pVZlodX
What I2s audio codec is used? -
Dear Katran
I2S support is currently not enabled in Linux. We are working on it but we are waiting for an input from Intel.
At first we will be enabling the HiFiBerry family of boards (https://www.hifiberry.com/products/dacplus) that uses a PCM5122 codec and to obtain I2S output on the hat.
If you have a custom codec once we get that to work you can add your custom Linux machine driver to support it.
For now as I said your best options is to use an external USB sound card.
Best Regards
Nicola Lunghi -
Will Up Board work in Slave mode after it be connected to I2s DAC and this DAC will be work in Master mode ?nicola-lunghi wrote:Dear Katran
Best Regards
Nicola Lunghi -
currently I2S is not enabled due to a bug with the Intel driver.
as I said earlier we are working on solving the issue
Nicola Lunghi -
Are there any updates on this topic?
Hi @ccalde
is there still no way to get i2s working?
Does it work on any OS? -
You can follow this discussion for I2S status.
https://forum.up-community.org/discussion/707/i2s-sound#latest
Thanks @eduncan911 , I have seen that, nothing there either. The mod comments are about Linux though, not W10.
